dieser Radlauf?
Roland
Nächstes Rätsel - zu welchem Auto gehört...
Roland 500 SEL -
2. Januar 2009 um 22:54
Es gibt 3 Antworten in diesem Thema, welches 63 mal aufgerufen wurde. Der letzte Beitrag (
M06 Straight-6
Front Longitudinal
Roots-Type \'Elephant\' Supercharger
SOHC, 2 Valves per Cyl
Twin Mercedes Updraft Carburetors
7069 cc / 431.4 cu in
bore 100 mm / 3.94 in
stroke 150 mm / 5.91 in
power 223.7 kw / 300 bhp @ 3400 rpm
specific output 42.44 bhp per litre
bhp/weight 165.38 bhp per tonne
torque 687.4 nm / 507 ft lbs @ 2000 rpm
body / frame Steel Body over Ladder-Type Steel Frame
front tires 6.00x18 Michelin
rear tires 6.50x18 Michelin
front brakes Drums
rear brakes Drums
steering Worm & Nut
front suspension Solid Axle w/Semi Elliptic Leaf Springs, Houdaille Hydraulic Shock Absorbers
rear suspension Live Axle w/Semi Elliptic Leaf Springs, cockpit-adjustable Siata Shock Aborbers
weight 1814 kg / 4000 lbs
wheelbase 2946 mm / 116 in
gear ratios :1
top speed 193.1 kph / 120 mph
One of the most revered sports cars in the world is the SSK and this one features the most dramatic body of them all. It\'s nicknamed after Carlo Trossi who was its first owner and had close connections to the industry. In fact, he had the foresight to be an initial investor of Scuderia Ferrari and later became the team\'s President.
Trossi knew where to get the best cars in the world and he purchased an SSK when it was a sports car of choice. They were designed by Ferdinand Porsche and became known as White Elephants for their brute force. The series started with the 1927 Type 680 S and matured with the shortened 720 SSK. They had a brilliant racing career and were praised for their famous history. Only five original SSKs survive today and each is a \'holy grail\' among car collectors.
While most of the SSKs featured purposeful bodywork and cycle fenders for competition, a few were sent to the premier design houses to be fitted with an elegant body. Our feature car was purchased by Trossi after its competition career was over and he sent it, chassis number 36038, to Willie White who fashioned a body of steel. White was a relatively unknown coachbuilder and he formed the body to Trossi\'s design which probably explains why the car is simply known as the Trossi Roadster.
The most noticeable feature of the body is its teardrop profile which is emphasized extended fenders that have accent lines along their highest edge. The split wind shield is well integrated and mimics the front radiator\'s angle. The hood\'s trailing edge is also shaped to match the rake of windscreen and meet up to its base. Whether these features were designed by Willie White or Carlo Trossi, they were trend setting and later adopted by French design houses.
The cabin has no doors, but once inside the occupants are treated to custom dash board complemented by a huge Mercedes-Benz steering wheel. Most of the dials are standard Mercedes-Benz fare, except for a Jaeger ammeter. The speedometer still contains the same markings used by Count Trossi to keep track of engine rpm.
Behind 18 inch wheels sit huge copper brake drums that were originally designed to aid brake cooling. These wheels may have been originally red, but were changed to better match the elegance of the design. This is also true of the upholstery color which was green, but is now black.
Underneath the hood is an engine that completely fills the bay. Displacing nearly seven liters, the inline-six provides a full 300bhp thanks to an \'elephant\' supercharger that came straight from the special SSKL. Like them, the forced induction is stepped and only engages when the accelerator is fully pressed. It translates into 300bhp at 3400rpm and 507lb ft lbs at 2000 rpm! It\'s a wonder that any brakes, yet alone pre-war drums would be able to cope with the forces of such power and two tons of weight.
Supposedly, Count Trossi bought and sold this car several times from when he first registered it in 1932 through 1949. It eventually ended up with Ralph Lauren who had it comprehensively restored by Paul Russel and company. After 5000 work hours and two years, the car debuted at the 1993 Pebble Beach Concours where it won Best In Show. The car doubled this trick and it\'s price tag by taking the 2007 Villa d\'Este Concours Best in Show aswell.
:waving:
Eric K. -
Dieses Thema enthält 2 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind, bitte registrieren Sie sich oder melden Sie sich an um diese werbefrei lesen zu können.
Brunei R129 x3 4
- Duff Man Reloaded
27. September 2019 um 14:08 - MB-Exotenforum
- Duff Man Reloaded
22. September 2025 um 15:04
- 4
- 1,4k
Zu Mein Benz & ich Folge #15 - Vom Daily Driver zum Profi (Xenon für 5€ In-Benz-Kauf) 2
- MBBAUREIHENDE
22. September 2025 um 00:00 - Podcast: Mein Benz & ich
- MBBAUREIHENDE
22. September 2025 um 14:10
- 81
Brunei Exoten 23
- Duff Man Reloaded
25. November 2024 um 22:21 - MB-Exotenforum
- Duff Man Reloaded
22. September 2025 um 13:27
- 23
- 2,1k
23
Sultan of Brunei custom 1991 R 129 with 1745 (!!) km for Sale : WDB1290662F031713.......... 8
- Eric K.
22. Januar 2013 um 21:53 - MB-Exotenforum
- Eric K.
22. September 2025 um 13:13
- 8
- 302
8
14. September 2025 bis 21. September 2025
- MBBAUREIHENDE
21. September 2025 um 05:25 - Statistik
- MBBAUREIHENDE
- 29
